3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Hi fellow Bolters. Anyone installed the cardboard kick panels in their truck? Mine don't look like they would fit without some trimming and there is a 3/4" gap at the bottom. Or are you supposed to trim them? These are JC #UP2471. Anybody have a pic of them correctly installed? Thanks!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i had to make one out of a box one time for mine i just used the pass. side as a template and painted it cab colors and couldnt tell the difference. then i got abs kick panels with speaker pods from an outfit called "rod doors" in your neck of the woods. they fit like a glove. i remember him saying there was a difference between 40 and later but i can confirm that. if there a difference then maybe there is a universal set to fit both with some trimming required ???
there should be no gap on the bottom. the panel sits on the floor/firewall and behind the lip on the floor. slight trimming in the form of a corner notch out where the top of the panel meets the dash and front of the door jamb. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks, Ashton. No gap at bottom will require modification. Guess I'll make a cardboard template and compare it to the new ones and go from there.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | here a look a my abs panel. it sits on the fforewall and the bottom and the notchout is at the top, you cant see it but its there http://rides.webshots.com/album/580101010ErUoTd | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | AH-HA! Looks like there is a nice metal strip that holds the door edge in place. I don't have those; may be able to fab some at a friend's place with his shear and brake. A picture sure helps. I just added a photo of the floor mat I installed today, and you can see the kick panels just temporarily in place. Thanks!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | [quote=40casey]AH-HA! Looks like there is a nice metal strip that holds the door edge in place. I don't have those; quote] you can get them at carters also. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks, I checked after I left that message and found a couple of places have them. For the price, I'll just order them. Thanks again, and your big bolts are cool!!!
