1 members (RLB),
101
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74332 03/06/2007 6:24 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | I followed a link from somewhere here and ended up learning more about gasket sealers. The Hylomar looked rather impressive. The problem is that the price also looks impressive... http://www.hylomar-usa.com/_resources/_html/order.html Has anyone here used this? Would you recommend something else? I am thinking of this stuff for the rear axle cover right away...and other covers if/when I pull those. 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#74333 03/06/2007 6:53 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | sablesurfer - I have mentioned this stuff on this site before and it is the best thing I have found. I would recommend this stuff and it is available over the counter at any GM Dealership. It has worked when ALL of the others didn't. It is: GM Gasket Sealing Compund 1#1050026 Gr.8.800. It never hardens or dries out. Temperature range from -50F to 400F. I first used it on the rear end housing of my truck and have since used it on all other components of the truck. I think you will be happy with it! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#74334 03/06/2007 6:55 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | sablesurfer, As long as you asked...no goop! If the surfaces are clean, dry and flat then the seal is 99.9% mechanical. I use HIGH TACK aerosol. It's a contact adhesive which holds the gasket where it belongs and adds the .1% goop factor to seal things like cork gaskets. If you application calls for a gasket then it probably doesn't call for a glob-o-goop too! Dirty mating surfaces with 'pooched' bolt holes and overtightened fasteners are the cause of leaks most of the time. A dab of goop here or there is OK, but not hanging out of every crack like hemorrhoids. Stuart | | |
#74335 03/06/2007 7:16 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by atomarc: sablesurfer,
Stuart The thing about 'roids made me laugh. I have replaced a number of engines seized up/knccking due to globs of silicone(from a previous repair) clogging the oil pump pickup. Never understood the "some is good, more must be better" fellas. | | |
#74336 03/06/2007 7:23 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | You don't have to spend that amount on a sealer,,ask your parts counter gent and use your head on where and how much..doc | | |
#74337 03/06/2007 8:24 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | LOL....ok....just a little dab'll do ya'....I'll remember that...no hemorroids on my truck. (But I will admit, in case anyone looks closely, I used sealant on my exahust side to seal up what is technically a warped exhaust manifold...but only a bit.) 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#74338 03/07/2007 6:15 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I use motor oil on most gaskets. | | |
#74339 03/07/2007 2:32 PM | Joined: Apr 2004 Posts: 5,081 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,081 | Dave,
Don't have your answer but I have a surprise for you: There's your truck and story!
Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | |
#74340 03/07/2007 3:48 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | Woo Hoo.... Now people won't think I have an imaginary truck...  1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#74341 03/07/2007 4:42 PM | Joined: Apr 2004 Posts: 5,081 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,081 | As much as you are in here, I figured it would help! Peg
#74342 03/08/2007 7:56 PM | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I use good old Aviation Form-a-gasket. Used sparingly, a thin coat works great and seals gaskets & metal-to-metal surfaces. Cheap effective & easy to find. Used it for years with no issues, but still comes down to proper surface preperation of course. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
