5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
I followed a link from somewhere here and ended up learning more about gasket sealers. The Hylomar looked rather impressive.
The problem is that the price also looks impressive...
http://www.hylomar-usa.com/_resources/_html/order.html
Has anyone here used this? Would you recommend something else?
I am thinking of this stuff for the rear axle cover right away...and other covers if/when I pull those.
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
sablesurfer -
I have mentioned this stuff on this site before and it is the best thing I have found. I would recommend this stuff and it is available over the counter at any GM Dealership. It has worked when ALL of the others didn't. It is:
GM Gasket Sealing Compund 1#1050026 Gr.8.800.
It never hardens or dries out. Temperature range from -50F to 400F. I first used it on the rear end housing of my truck and have since used it on all other components of the truck. I think you will be happy with it!
Joe smile
sablesurfer,
As long as you asked...no goop! If the surfaces are clean, dry and flat then the seal is 99.9% mechanical. I use HIGH TACK aerosol. It's a contact adhesive which holds the gasket where it belongs and adds the .1% goop factor to seal things like cork gaskets.
If you application calls for a gasket then it probably doesn't call for a glob-o-goop too!
Dirty mating surfaces with 'pooched' bolt holes and overtightened fasteners are the cause of leaks most of the time.
A dab of goop here or there is OK, but not hanging out of every crack like hemorrhoids. eek
Stuart
Quote
Originally posted by atomarc:
sablesurfer,
Stuart
The thing about 'roids made me laugh. I have replaced a number of engines seized up/knccking due to globs of silicone(from a previous repair) clogging the oil pump pickup. Never understood the "some is good, more must be better" fellas.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
You don't have to spend that amount on a sealer,,ask your parts counter gent and use your head on where and how much..doc
LOL....ok....just a little dab'll do ya'....I'll remember that...no hemorroids on my truck.
grin
(But I will admit, in case anyone looks closely, I used sealant on my exahust side to seal up what is technically a warped exhaust manifold...but only a bit.)
I use motor oil on most gaskets.
Authorized Pest
Authorized Pest
Dave,
Don't have your answer but I have a surprise for you: There's your truck and story!
Peggy
~ Peggy M
1949 Chevrolet 3804
Woo Hoo....
Now people won't think I have an imaginary truck...
grin
Authorized Pest
Authorized Pest
As much as you are in here, I figured it would help!
smile
Peg
~ Peggy M
1949 Chevrolet 3804
I use good old Aviation Form-a-gasket. Used sparingly, a thin coat works great and seals gaskets & metal-to-metal surfaces. Cheap effective & easy to find.
Used it for years with no issues, but still comes down to proper surface preperation of course.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
