2 members (Johnnydog, 78buckshot), 95 guests, and 2 robots.
Topics128,060
Posts1,055,832
#743001 04/27/2011 11:16 PM
I have a 49 chevy 1-ton truck, I have rebuilt the Huck wheel cylinders, Had the shoes relined, And drums resurfaced, When my shop was cool, I adjusted the brakes, After I get the temp. of my shop to 75 degrees the brakes lock up. Is this a vent problem?
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Never had that situation but my first instinct is the brakes are adjusted to tight.
I'll second the over-adjusted theory.
Sounds to me that there's just enough heat expansion going on the cause the bind.
Try backing them off a tad and see what happens.
More pix on Flickr.
I had problems with brakes like this before, drove me nuts. I finally had to bevel the ends of the brake shoes.(the lining)I noticed after that, that most of the replacement shoes already had a slight bevel on the ends, but not neccesarily. The best I could figure the shoes were slightly bigger than the drum and just stuck in drum, after they ran awhile and got worn to the same profile as the drum it was fine.
This is something I used to do on all my VWs. It also stops the new shoes 'grabbing' the drum.
I think it's just good practice to do.
Especially important on something as light in the front as a VW Bug!
More pix on Flickr.
well what happened?
