10 members (SmalltownTRKGuy, Njm, Hotrod Lincoln, walter74, baldeagle, cmayna, Woogeroo, Ponchogl, 2 invisible), 348 guests, and 7 robots.
Topics128,165
Posts1,057,089
Members48,463
How can I add an insulator between the carb and intake manifold on my '54 3100 235 w/Rochester B? The carb doesn't have an insulator and the mounting studs are too short to add one.
Can I (easily) replace the studs? What do I need? Where do I get them?
I have an insulator from Chevs of the 40's.
The truck runs OK, but since I am going to rebuild the carb (to improve the accelerator pump operation) and add new lines, I'll add an insulator while I have the carb off.
(There is another thread running that touched on the subject.)
Thanks for your help,
- Lonnie
My '54 3104
H Online: Content
The studs are simple screw-in items, but several decades of being threaded into the manifold might make them a little hard to remove. I'd suggest threading two 3/8-24 nuts onto the stud, and jamming them tight together, then using the lower nut to try to back the stud out of the manifold. If it's stubborn, apply penetrating oil, and heat if necessary. Vise grips or a small pipe wrench are a last-resort method. Just don't twist one off trying to get it out. The stud will have a 3/8-16 thread into the manifold, and 3/8-24 threads at the carburetor flange. They're standard hardware items, but you might need to find an industrial supplier like Grainger or MSC, etc. to find a good assortment of lengths to fit your needs.
Jerry -
You are always right-on! Thanks for the info. I'll remove the carb next week and start soaking the studs with MasterBlaster. The thought of twisting one off inside the manifold makes my skin crawl!
I assume that I should buy hardened studs and wipe on some anti-seize when I screw them in.
Thanks again.
- Lonnie
My '54 3104
H Online: Content
For no more torque than they'll get holding the carb on, Grade 5 will be OK. Grade 8 would be a bit of overkill, I believe! Anti-sieze is always a good idea!
You can go to a FLAPS and get the studs they use them for exhaust pipe to manifold apps.
Pete
Thanks Pete,
That's good to know. I'll post my results when I get everything back together.
- Lonnie
My '54 3104
