9 members (lumbersawyer, Jon G, MickeyP, Joe H, 55shaker, 3B, 68ironhead, VEW, Pre '68 Dave),
56
Mod | | | Forums66 Topics128,175 Posts1,057,115 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Got pitting on both seal and bearing surface, needs to be addressed before destroying bearings. Assuming used axles are available, what are the chances they'll be in good shape? Also, has anyone done the speedi-sleeve? Is it something I can do at home? I'm pretty competent but no special tools.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You can buy offset bearings that will run just off the track that the old bearings ran. This would give the bearing a new axle surface, next to the old ,to run on. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | I used a speedi-sleeve on my rear end. They include a cup that fits over the sleeve, and you gently hammer it on. Once it's where you want, you remove the lip you used to hammer it on with. Pretty easy. If the surface is really worn down, you might want to build it back up before putting the sleeve on. I can't remember what they recommended for building it up with. Maybe someone else here knows.
| | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | Sorry, I just realized you were talking about the axle itself. I used a sleeve on the pinion. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Thanks for the link Grigg, I wasn't finding it during search. Offset bearings should work for my needs, but what caused me to pull the axles was oil on the brakes due to pitted seal area. Sleeve would probably work if it could be used in conjunction with, or instead of offset bearings.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You could have the axle or seal surface spray welded and reground, might not be cheap but is probably the proper way, other than just replacing the axle.
JB weld and other metal repair epoxies can be used to fill pits in a seal surface with pretty good results, but a sleeve repair would be better. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Someone posted a while ago that they were getting new axles made. I don't know the size of truck but that would be a #1 option, I would think. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | New axles are available, but youn have to swap out the spider gears as the splines are different. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Wondered about that repair sleeve. Don't understand the measurements though. My half-ton gets the 414045 seal which is shaft 1.875 and bore 2.782, which doesn't jive with the repair kit's listing of 2.844 and 3.939.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if you use the speedi sleeve it has instructions regarding what and how to fill in pits and what not. They are wonderful in my opinion, (they can also be replaced if THEY start grooving) If the measurements don't match you don't have the right one. of course the shaft will be slightly bigger. The seal will stretch quite a bit. I have used a lot of these at work, and I have yet to find an application they don't have a sleeve for, (there is hundreds of them) just get the measurement of the shaft diameter, and chose the sleeve accordingly, the seal should be the same
| | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | What axels are you working with 1/2 or 3/4 ton ??? | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | 1/2 ton- anyone know the measurements?
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if you have the axles out just measure them. if you don't have any precision measuring tools, all you would need for this is one of the plastic dial calipers available almost anywhere. this isn't all that precision. or if there is bearing numbers, go to the bearing house and they can give you exact dimension, as well as that of the seals if you can get a number off of them. | | |
