8 members (Wally / Montana, Donf, DoubleB, Otto Skorzeny, tclederman, BillCollins, C10 - C90 Bill, HandyAndy),
57
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Hi got an electric fan conversion but i cant get enough clearence with the water pump that is on my truck its a 1954 3600 stock motor stock radiator . My question is there a shorter shaft water pump that will give me the clearence I need too get the cooling fan in behind the radiator
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Ok figured it out changed the Electric fan too a pusher and mounted it in front So will either run a two fan setup the mechanical one and the electric as a backup or just the electric one taking off the mechanical one
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I have an electric fan I put on the front of my radiator on a '37 Chevy coupe with a 261 in it. It does fine. I do have a 12 volt system with a 100 amp alternator. There isn't any problems to date and I race this one. Normbc9 | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The stock fan setup would be the best setup on a 54 truck with a 54 engine. If the engine has been upgraded to a later model 235 and you are finding a lack of clearance for the stock fan setup you need to check out the "water pump adaptor plate" conversion which properly positions the water pump higher on the radiator, gives you additional clearance for your pulleys/belts, provides you with the proper fan speed and let's you use a stock early waterpump that is available at most local parts houses.
The so-called "short water pump" addresses NONE of these issues and the overpriced pump is available only through mail order. The stock fan setup using the adaptor plate is simple, inexpensive, and once it's installed you'll not have to give it another thought.
I've outlined the adaptor plate install process in my Webshots Chevy albums.....hope this helps.
Dave | | |
