0 members (), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,454
#742412 04/25/2011 7:59 PM
Hey there, im new on here and just got my 1953 GMC on new years... well at least i think its a 53, the previous owner got it in his dads will and believes its a 53 but my VIN says otherwise. The only problem I've ran into is it doesnt have the original engine in it... engine VIN doesnt match on the door VIN, does anybody know how to read them? I've got the truck turning over, just had the carb rebuilt but forgot to pick it up before the weekend, hopefully it will start up now. but i think my vacuum might be dead. is there anyway to tell?
the truck engine number and number on the cab plate would not have been the same. the government could have used either one to register the truck with.
Check out the tech tips at the top of this page for help with identification. If that fails there are some great guys on here that can and will help you out. Welcome to stovebolt.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Judging from the photo link you posted in the dity forum, I'd say it's a '53 and not a '54 judging from the dash. (I didn't see any grille photos)
Steve
'49 3800
'52 3600
'57 3100
Im guessing its either a late '53 or maybe early '54 just pieced together with left overs, its got the grill from all previous years.
Does anybody know anything about the vacuum? im pretty sure my wipers are vacuum operated but there not working and fuel suction into the carb is pretty low (i dont have an air filter on it so i just put my hand over the top of my carb, not a lot of suction)
3B Offline
Hy Josh_53GMC, Welcome, if you would post the numbers from the door post we could tell you what it should be. You won't feel a lot of vacuum with the engine just cranking over, unless you completely cover the top of the carb, your vacuum accessories will not operate without the engine running, hope that helps.
tclederman
the good and the bad with this truck is its a barn find, fresh out of saskatchewan... bad news is the engine is covered in mud, in some spots its close to an inch thick, i did manage to scrape away enough to see some numbers on the intake manifold
but nothing by the distributor
Josh,
I deleted my earlier post about engine codes (etc) because it is a Canadian GMC - foreign territory for me.
Looking at your flickr page 4 photos, it's a 1953 GMC cab - split windshield and the dash is not a 54 dash (it is 53 or earlier).
Hi Josh, nice truck.It looks like your truck has vent windows and drop down door handles which only happened in 1951.You might have to change your user name
yeah, im waiting for an admin to approve it... the guy i bought it off of said it was a '53, then i had the VIN read and it came up as a '54. then 3B told me it was a '51, which makes perfect sence. all the dash components on the back say '51
Moderated by  Dusty53
