5 members (Bucker, 55shaker, 2-Ton, TUTS 59, 1 invisible), 158 guests, and 2 robots.
Topics128,192
Posts1,057,351
Members48,469
Question came up when I had the original radiator re-cored.... do I want high or low pressure system??? What is the advantage? I am going from stock 228 to 302 street rod/push truck.
The 228 used a 4 lb. cap. Modern V8s use 15 lb. or more. The higher the pressure, the higher the boiling point of water.
I don't know what pressure the 302 originally used so I can't make a recommendation.
i have a 4 lb cap on my 270 thats in the ashton and 235 thats in the 6100. the rad on the 40 is atmospheric so it doesnt matter what cap you put on it it aint gonna blow nor raise the boiling point. a five psi cap will allow it to reach 224 degrees. since i dont have my steam tables in front of me i cant tell you what 4 psi is. a seven pound cap will put you to 235 degrees.
From memory I think for each pound of radiator cap you raise the boiling point 3 degrees. Thus a 15 lb cap will raise the boiling point to 257 degrees.....if my memory is right.
Thanks guys,
I'm running a five jug Howard intake and may need the extra heat. What do you think?
If you are running an original heater you do not want to run much pressure or you could cause the core to leak.
My Blog
X2 - the limit is the oldest and weakest bit that sees pressure.
Ex Hall Monitor
Ex Hall Monitor
Excellent input Dave, I hadn't even considered the heater core.
