2 members (J Lucas, Erniegp), 78 guests, and 2 robots.
Topics128,054
Posts1,055,780
#742226 04/25/2011 3:11 AM
http://www.flickr.com/photos/46gmc/5652045114/in/photostream I noticed moisture on the front rim and pulled the rim and drum and this is what I found. The rubber ends look in good shape. I pushed them back on tighter , but , are they due for a replacement when they look like this? If you look close there is a drip on the right rubber.
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
Looks like the cups are going bad. While there should be some fluid there for lubrication (very little), that looks to be a definite leak. You should at least do a rebuild on them. Since you mention seeing fluid on the wheel, most likely the shoes are soaked as well, and should be replaced.
Bill Burmeister
Riding in the Passing Lane
Those are the boots. Pull them back a little. If there is fluid inside then there is leakage in the cups. You can put a kit in it easily. You will need a brake cyl. hone available at Chinese tool stores or parts stores.
1972 Chevy c10 Cheyenne Super
Where did those brakes come from? They are updated braked.
1951 1 Ton Completed
The po would have done the brakes,I had a file with all his invoices , can't find it now. btw both sides have fluid behind the boots when I checked. I expect rears will be the same. Thanks all
Here is a better pic of those brakes truckernix if anyone wants to see them. www.flickr.com/photos/46gmc/5651475597/in/photostream
