7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | http://www.flickr.com/photos/46gmc/5652045114/in/photostream I noticed moisture on the front rim and pulled the rim and drum and this is what I found. The rubber ends look in good shape. I pushed them back on tighter , but , are they due for a replacement when they look like this? If you look close there is a drip on the right rubber. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like the cups are going bad. While there should be some fluid there for lubrication (very little), that looks to be a definite leak. You should at least do a rebuild on them. Since you mention seeing fluid on the wheel, most likely the shoes are soaked as well, and should be replaced.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those are the boots. Pull them back a little. If there is fluid inside then there is leakage in the cups. You can put a kit in it easily. You will need a brake cyl. hone available at Chinese tool stores or parts stores. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Where did those brakes come from? They are updated braked. | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | The po would have done the brakes,I had a file with all his invoices , can't find it now. btw both sides have fluid behind the boots when I checked. I expect rears will be the same. Thanks all | | |
