1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#7418 06/22/2003 2:22 AM
Pal
Offline
On 68 250. I am replacing the engine, which did not come with a pilot bushing. I went to a parts store, and recieved a pilot Bearing. It's the same shape and size as the old brass bushing, but has needle bearings inside. Q: should the bearings be toward the tranny, or should the beveled side go towards the tranny. Checked the Chiltons, no luck. Help!
35 + years of rollin' steel!
#7419 06/22/2003 6:50 AM
The pilot bearings that I have used, have a small seal at one end. That seal should be towards the trans.
My Blog
#7420 06/22/2003 4:06 PM
Pal
Offline
That should do it. Thanks.
