7 members (JW51, 3B, cshades, cmayna, Gdads51, moparguy, 1 invisible), 103 guests, and 5 robots.
Topics128,064
Posts1,055,860
Members48,428
#741726 04/23/2011 1:36 AM
O.K. Now I started it!
Pulled the engine for a rear main seal job and decided to have my heads machined. I am looking at harded exhaust rings and three angle job.
Also thinking about new lifters,rockers basically all upper end.
I need advice for my lower end, as I really do not want to touch it.
What do you think?
Born Lucky #741760 04/23/2011 3:19 AM
How was your oil pressure and compression?....curt
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
Curt Guild #741835 04/23/2011 12:26 PM
I removed the engine because a rear main seal leak so I never did take compression.
I never did think about that because the engine was felt good. It always atarted right up and always pulled hard. I am still tearing her down so I will check for ridges along the cylinder walls.
