| | | Forums66 Topics128,163 Posts1,056,920 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74136 03/02/2007 7:05 AM | Joined: Dec 2006 Posts: 24 Junior Member | | Junior Member Joined: Dec 2006 Posts: 24 | ok guys, ive heard a lot of swaps being done with late 70's camaros/trans ams. I have a 2000 Trans Am disk rear end with 3.42 gears. I am also going with a Small block 350 and a TH400 transmission. Please give me any input/opinions you all may have. Should i do it? Thanks in advance. http://community.webshots.com/user/1951GMC | | |
#74137 03/02/2007 6:40 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Why a TH400? They are far heavier than a TH350 and consume more than twice as much power.
If you need the strength of the TH400 you might want to consider a 9-inch Ford rear instead of the Trans Am rear.
My two cents...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#74138 03/02/2007 10:29 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Honestly I would consider going with a 700r4. That rear end has a pretty tall gear for only wanting to run a 3 spd trans.
Just my 2 cents
Wilbur | | |
#74139 03/06/2007 12:27 AM | Joined: Dec 2006 Posts: 24 Junior Member | | Junior Member Joined: Dec 2006 Posts: 24 | Ok keep em coming
OldSub: The reason im going with the 400 is because it came with the engine. I also have a stock 9"rear end from a late 70's Lincoln but i think it would be to much of a mess for me to cut it to size and make it a posi. What do you think worth the trouble?
wilbur: the 700 r4 was my first "want" but i cant seem to find one that is going for a reasonable price. what do you think is a good price for one.
the bottom line is that the parts that i have mentioned is what i have available to me. and when it comes down to it. it all has to do with money (lol)
guys please keep your opinions or thoughts coming i welcome them all.
thank you | | |
#74140 03/06/2007 1:24 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | How wide is that Lincoln rear? You want something about 62 inches wide. The 9 inch is the strongest car type rear out there and would be more consistent with that TH400... And late 70's the gears are probably gas mileage friendly too.
#74141 03/07/2007 1:23 AM | Joined: Feb 2007 Posts: 17 Junior Member | | Junior Member Joined: Feb 2007 Posts: 17 | I'm running an 87 firebird axle, 3.27 gears and 700R4 in my 53...great combo, in town and on the freeway (that overdrive is the ticket). | | |
#74142 03/07/2007 5:17 AM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I believe the firebird 2000 is to wide to fit your 51 without backspacing. Those disc brakes will bolt right up to a 10 bolt Camaro rear late 70s early 80s. Good Luck and keep your tape measure working.
~Jim
