0 members (), 110 guests, and 1 robot.
Topics128,196
Posts1,057,394
Members48,471
#740930 04/20/2011 3:40 PM
LJS
Offline
Can someone tell me how to identify a Hydramatic as to what year it is and what it came out of. I have a Hydramatic that I was told came out of a 50s Chevy truck. I'd like to know what it is.
Lee
3B Offline
Hy LJS, have you checked the transmission case for a rivited on tag, if you can give us the numbers from that tag we could possibly identify it for you. In the mean time, does it have a torque tube connection at the rear, or open drive tailshaft, is there a parking brake mount on the tailshaft??? I think the tag was rivited on the rear of the transmission just above the oil pan, hope that helps.
LJS
Offline
I've got pictures of the tag and trans, but I'll be %^&* if I can figure out how to load them on this forum.
LJS here is a pic of my Hydra-Matic tag The CH54 refers to the year I believe... Mine is in a 1954 3104... I have not seen a transmission cast identification web site like there is for engine blocks...
To post pics here you have to have them on an off site host like one of these ... Once your pics ore on the host site you need to be in the Full Reply Mode... Select the Icon next to the Smiley Face and a pop up will appear, then copy and past your link address and click OK ( make sure you are not logged in on your host site, you must be in Guest Mode or your link address will not work) then a new pop up will appear, give your link a name/title click OK and your set...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
I believe the earliest was in 53 in GMC though it may be out of a 1/2 to 2 ton truck if memory serves me right . Chev had them here first in 54.
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
First domestic production GMC to have a Hydra-Matic was in a 1952 PM-150-22.
In 1953, GMC had the H-M transmission as an option in 1/2, 3/4, and 1 ton trucks (100, 150, 250).
In 1954, when Chevrolet trucks first had a H-M as an option in 1/2, 3/4, and 1 ton trucks, GMC had several versions of Hydra-Matics for almost all sizes of it trucks. This included a 21 forward gear oddity (which was basically two Hydra-Matics mated side-by-side, connected to a shared output shaft).
As stated above, the transmission ID plate (on the transmission or on the engine) would be the most convenient way to ID the transmission.
LJS
Offline
Thanks for the replys. Looks like this is a 53 or 54 trans for a open drive shaft.
This will be going up for sale soon. Have trans, bell and adapter for 6 cyl., some column linkage and starter.
NO TORUS OR FLYWHEEL.
*******[b]Need flywheel for Chevy V8 to Hydramatic******************[/b]
