7 members (Joe H, Charles in CA, WICruiser, dt235sd, Donf, JoergK., 1 invisible), 101 guests, and 1 robot.
Topics128,259
Posts1,058,301
Members48,485
#740654 04/19/2011 5:09 PM
I'm getting ready to install a fuel line on my 1949 chevy truck. The guy how had it before me used a fuel hose from the tank to the pump.I have 5/16 brake line and want to mount the line to the frame. There isn't a clear picture in any of my shop books. I purchased a shut off valve for the tank and the male openning in the valve looks like a brake compression fitting. Do you run the hard line from the tank to the pump or is there a break somewhere for rubber? any help and pictures will be a big help!
Thank you for your help!
heres a pic off my 1950 3100
...pic...
Factory Assembly Manual will show the routing of the line.
Original was a short pre made flex hose with inverted flare fittings, then the steel line in the frame all the way to the pump.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thank you for the picture DAD50 thats what I needed.
Just a note,
The fuel filter at that location was there when my Dad bought the truck in 73.
I left it at the location but others place it after the fuel pump up by the carb.
Good Luck
