1 members (Paul Mullen),
109
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | I'm getting ready to install a fuel line on my 1949 chevy truck. The guy how had it before me used a fuel hose from the tank to the pump.I have 5/16 brake line and want to mount the line to the frame. There isn't a clear picture in any of my shop books. I purchased a shut off valve for the tank and the male openning in the valve looks like a brake compression fitting. Do you run the hard line from the tank to the pump or is there a break somewhere for rubber? any help and pictures will be a big help! Thank you for your help! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | heres a pic off my 1950 3100 ...pic... Factory Assembly Manual will show the routing of the line. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Original was a short pre made flex hose with inverted flare fittings, then the steel line in the frame all the way to the pump.
Grigg | | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Thank you for the picture DAD50 thats what I needed. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Just a note,
The fuel filter at that location was there when my Dad bought the truck in 73.
I left it at the location but others place it after the fuel pump up by the carb.
Good Luck | | |
