1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 6 New Guy | | New Guy Joined: Apr 2011 Posts: 6 | Thinking of buying 1954 3100. Engine is painted blue and has NEW BLUE FLAME 136 on valve cover.
Is this engine an original engine? Engine code from block has a 1955 year.
Regards, Jay Bonica
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 1955 dated engine would not have been used in 1954. 1954/55 truck engines were originally painted gray and car engines were painted blue (rebuilt/repainted engines could be painted any color). Here are locations of various codes on engines - some locations might be different in different years and on cars vs trucks. Post the block and head casting codes, the block and head date casting codes, and the engine serial number/ID. People will help to ID the engine. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | If it is a true Blueflame 136, it would be for a passenger car with Powerglide transmission and have hydraulic lifters. I believe that a Thriftmaster would be the correct engine for the truck. | | | | | Joined: Apr 2011 Posts: 6 New Guy | | New Guy Joined: Apr 2011 Posts: 6 | Tim: I agree this engine is from passenger car...wanted truck to be numers matching matching but it's not.
Considering buying truck? Owner should have rebuilt original engine and not cut hole in dash for radio.
Thanks for the help, Jay
Regards, Jay Bonica
| | | | | Joined: Apr 2011 Posts: 6 New Guy | | New Guy Joined: Apr 2011 Posts: 6 | I agree....owner made big mistake replacing original engine and cutting hole in dash. Might not buy. thanks jay
Regards, Jay Bonica
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Tim: I agree this engine is from passenger car...wanted truck to be numers matching matching but it's not.
Thanks for the help, Jay That should not distract you. Most will never know that it is incorrect for your truck. The engine will be quieter and you will have more horsepower Paint the engine grey and remove the blueflame decal and replace it with a Thrisftmaster decal. The dash can be repaired with available patch panels. | | |
