| | | Forums66 Topics128,105 Posts1,056,209 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 29 | I'm changing the stock 3/4 ton 15 inch rims to the optional 17 inch 3 piece rims and I need the correct gear for the speedometer cable into the tranny for correct speedometer reading. Anyone have a part number or contacts?
Currently running 4:57's front and rear differentials
Joe
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Place a Want Ad in the Swap Meet. There is at least one member who sells those items.
| | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Jim Carter will make one for you, Let them know the speed you are driving, And the speed your speedo is showing. And they will send the gear to correct this. I used my garman to find actual speed. I changed mine from a 5.13 to 4.56
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Feb 2011 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 29 | Thank you,
I'll check out Carter.
Joe | | |
