0 members (), 90 guests, and 6 robots.
Topics128,089
Posts1,056,141
Members48,436
#738876 04/13/2011 5:45 PM
2 Offline
I'm changing the stock 3/4 ton 15 inch rims to the optional 17 inch 3 piece rims and I need the correct gear for the speedometer cable into the tranny for correct speedometer reading. Anyone have a part number or contacts?
Currently running 4:57's front and rear differentials
Joe
Place a Want Ad in the Swap Meet. There is at least one member who sells those items.
Jim Carter will make one for you, Let them know the speed you are driving, And the speed your speedo is showing. And they will send the gear to correct this. I used my garman to find actual speed. I changed mine from a 5.13 to 4.56
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
2 Offline
Thank you,
I'll check out Carter.
Joe
