0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | The truck is a 1953 half ton with a 261 and is converted to 12 volts. The foot starter usually works well but sometimes, when I depress the foot starter, it grinds as if the flywheel and starter aren't meshing properly. Is there a spring or something that may need to be replaced? What should I look for? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are you using the 1953 clutch assembly and 1953 flywheel?
If yes, the teeth on the flywheel is for a 6v starter - are you using a 6v or 12v starter?
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'm using the 1953 clutch and flywheel, which is identical to the later flywheel. Also the 6v starter. As mentioned, it usually works well, maybe one time out of four, it grinds, not sure if its actually the flywheel or something in the starter. | | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | This is a common problem I believe with worn starter drives. 6 volts does not matter with 12 v. driving it. flywheel is 139 teeth Starter with nine is correct combo. When the starter is depressed it can stop inbetween teeth. When it is pushed further, the spring in back of the starter drive is compressed. When contact is finally made electrically, the starter drive will turn and snap into the flywheel, because of the spring pressure on it. If it grinds it is because of one of wear on drive or flywheel.
Plattelnjpichler
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | One of my starters has a worn drive. The one way clutch is damaged in such a way that it is loose in the housing. I started to have grinding noises with it and it did some damage to the flywheel very quickly. That thing can destroy your ring gear in no time. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | When you push the starter button is it pushing the switch correctly? Could be something is out of adjustment? | | |
