Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#740165 04/18/2011 2:51 AM
Look for advice and ideas as usual.
I am working on installing a 216 valve cover to a 261 to make it look the old style. Got a set of new valve cover studs, rubber gromlets and the flashy acorn nuts....
I have spare 235/261 gaskets but no 216 gaskets.... but they have extra holes and don't seem as wide.
Should I be shoping for 216 gaskets...?
Any particular tricks to keep it from leaking... besides not over torquing the acorn nuts.
I have different sets of 216 valve covers BUT some are 25 inches long some are 26 inches long which fits the 261. What are the shorter 25 inches valve covers for...?
Any tricks for straightening the valve cover...?
I have already reproduced the steam pipe that runs from the back of the engine at the heat sensor outlet to the radiator tank and cannibalized the side mounted bracket for the coil... intending to fake the ignition connection cap at the rear of the coil using parts from an old armored wire coil connection. Dizzy appears original with a Pertronix inside.
Thanks for your comments and suggestions.
Bob C.
Bob C.
CMP Heaven
The Hammond Barn
RAC1812 #740230 04/18/2011 11:46 AM
The only advise I can give is about the gasket. To use the newer gasket cut off the tabs and use RTV to fill the four holes.
1951 1 Ton Completed
