0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Look for advice and ideas as usual.
I am working on installing a 216 valve cover to a 261 to make it look the old style. Got a set of new valve cover studs, rubber gromlets and the flashy acorn nuts....
I have spare 235/261 gaskets but no 216 gaskets.... but they have extra holes and don't seem as wide.
Should I be shoping for 216 gaskets...?
Any particular tricks to keep it from leaking... besides not over torquing the acorn nuts.
I have different sets of 216 valve covers BUT some are 25 inches long some are 26 inches long which fits the 261. What are the shorter 25 inches valve covers for...?
Any tricks for straightening the valve cover...?
I have already reproduced the steam pipe that runs from the back of the engine at the heat sensor outlet to the radiator tank and cannibalized the side mounted bracket for the coil... intending to fake the ignition connection cap at the rear of the coil using parts from an old armored wire coil connection. Dizzy appears original with a Pertronix inside.
Thanks for your comments and suggestions.
Bob C.
Bob C. CMP Heaven The Hammond Barn
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The only advise I can give is about the gasket. To use the newer gasket cut off the tabs and use RTV to fill the four holes. | | |
