4 members (Wally / Montana, FAST55, lumbersawyer, cmayna), 163 guests, and 1 robot.
Topics128,197
Posts1,057,259
Members48,466
Hiya, ive a 1953 Chevy panel truck, and am doing a Patricks rear end kit,
all is going fine, im just not sure what lubrication to put in both the rear end and the gearbox. (its an original 3 speed on the colum./)
can someone help as the "operators manual" states not to use straight mineral oil in Hypoid rear axles, but ive look into some things on here and they say use mineral?
also some stuff about brass bushes in the gear box getting worn / damaged if i dont put the correct lub in?
thankyou, Dan
1953..panel truck.I love my truck!...
The mineral oil is for a transmission with a Borg-Warner overdrive. Your transmission can use hypoid gear oil. That is for the differential also.
do i need to look for an oil that has "Meets requirements of API GL-5." or is Gl - 4 ok too?
will and of the above be sutable for the gearbox too?
thankyou for your help
Riding in the Passing Lane
GL-5. Practically everything meets GL-5 anymore. You can use it in the trans. & rear end.
1972 Chevy c10 Cheyenne Super
in the u.k i can pick up gl-4 and 5 from the local car place, in Patricks gear kit, he has mentioned straight 90w (mineral oil) ?..but as the original Operators manual say "caution straight mineral oil gear lub must not be used in hypoid rear axles ?" ??
im looking at other posts as well , to add to this ive also when changed by transmision fluid see that the oil is golden.?
anyone? thanks
You will want the same type oil in both. Like in a previous post some of the trans grease will likely leak back into the diff.
