| | | Forums66 Topics128,105 Posts1,056,205 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | How does the light switch work? When installed does the lever need to be in contact with the brake pedal? I'm about to install my rear tail lights and want to understand how to diagnose any problems. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | The switch is "normally closed- - -held open". That means the brake lights will operate anytime the pedal linkage allows the spring-loaded switch arm to move. The pedal bellcrank should hold the switch in the open position until you step on the brake, making the brake lights come on. Jerry
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Thanks Jerry. I got it working now. | | |
