4 members (Tom McGrath, TexasA&M48Truck, Otto Skorzeny, Gdads51), 97 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
How does the light switch work? When installed does the lever need to be in contact with the brake pedal? I'm about to install my rear tail lights and want to understand how to diagnose any problems.
The switch is "normally closed- - -held open". That means the brake lights will operate anytime the pedal linkage allows the spring-loaded switch arm to move. The pedal bellcrank should hold the switch in the open position until you step on the brake, making the brake lights come on.
Thanks Jerry. I got it working now.
