0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 3 New Guy | | New Guy Joined: Apr 2011 Posts: 3 | Hello, I just bought a GMC short bed with a 305 V6. I am interested in putting in a V8 down the line. Any suggestions as to which engine will best fit in this truck? This is my first project, I grew up working on trucks with my dad, decided it was time for me to get one for me. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I put a 409 in mine. The tops of the frame rails needed to be trimmed just a bit. I put a Turbo 400 behind it and used Sanderson headers. I did not put in power steering and did not change anything else on the truck. Eventually a 12 bolt posi should go in. A big block should be fine. A small block will be fine as well. A lot of the dismantlers have the 5.3L LS motors from the new trucks for very cheap money. The redone wiring harness and computer actually costs more than the engine. In my neck of the woods, I can get a 100k mile 5.3 with reworked engine harness, with the 700R4 behind it for around 1400 bucks. With 300 HP of fuel injected goodness, you're not going to get a better bang for the buck than that. And 22 MPG to boot and it'll fire up on the first key turn. I haven't done one yet, but that will be the direction for the next one for sure. Good luck. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | wbreeze: a small block Chevy is going to be the easiest swap. Cheapest, too. An LS is a great way to go, too, but if this is your first project, you need to adhere to the K.I.S.S. principle: Keep It Simple, Stupid.
K10: how'd you hang the TH400 in your truck? Did you make your own cross member? (I haven't seen an available aftermarket trans cross member for the '60-'62 trucks)
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Apr 2011 Posts: 3 New Guy | | New Guy Joined: Apr 2011 Posts: 3 | Thanks for all of the suggestions. I know they will be helpful in the near future. | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | hey, wbreeze, wish you lived closer to Utah. I'd offer to buy your 305 if it was still decent. Had one in a 80's truck, and was really fond of it. :-) Fun little motor with good zip. Good luck!
| | | | | Joined: May 2011 Posts: 5 New Guy | | New Guy Joined: May 2011 Posts: 5 | I agree with husker the 305 v-6 is an awesome work truck motor.. 63 gmc 3/4t 305 v-6 log truck lotta torque | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | And about 10 MPG. It's a heavy sucker too. The v-6 is 100 lbs heavier than the 409 I put in mine. Brad, I missed this before, Sorry. We welded a couple of tabs and bracing onto the front of the stock x-member, and kept it in the stock location. Downside is that the trans and engine would need to come out together, because of the "enclosure" at the rear of the trans. But other than that, it worked out slick. I went with a stock 3 on the tree column shiftand welded up the linkage and turned it into a column shift auto. I got a lokar column cable shifter kit and that was it. | | |
