6 members (CATMAN, tclederman, BarryP, DadsFirstPickup, Bill Hanlon, Millenimech), 95 guests, and 4 robots.
Topics128,154
Posts1,056,842
Members48,456
Hi all... Grant here. Bad news today... found out the 12 bolt 3:73 posi that I was planning on overhauling for my 59 Apache 1/2 ton is trashed beyond practical use. So now I am considering options. What is available to put into the original 3rd member rear end as far as ratios with a posi unit? I am mostly interested in 3:73 or 3:42. Thanks.
Am I suppose to guess you are talking about a 59 1/2 ton?
If yes, you are limited to 3.90:1, or 3.38:1. As far as I know there is no Posi options available for the HO33 rear.
Z
Z Offline
I know I have as S104wd rearend,that has 3:73 posi,and some of them have 3:42posi.I would think it is not an original 59rearend?My guess?
The only Posi unit for that rear was the Eaton Positraction, only manufactured from '60-'62/early '63. Nothing in the aftermarket exept for a Miller or Lincoln Locker wink.
Bill Burmeister
