Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (cmayna, jay d, 2-Ton, 2 invisible), 44 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
U
U Offline
Hi. I am new to the forum and am looking for some information. I have a 1954 Chevy 5 window pickup and I am looking for some information about the engine. I have looked at Tim's truck page. There are no numbers on the block where he shows the block casting code and no numbers where he shows the block date casting codes. In fact the only numbers I have been able to find on the block at all are the number 2 above GM on the front right of the block and the following numbers on the distributor plate 06577 30 F54M. The head casting number is where it says on Tim's page and is 3835913. Where else could the casting and date codes be? How can I find out more about this engine without those numbers?
Hi
I know the F stsnds for FLINT - MICHIGAN
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
1967 Austin A60 Pick-up,
1954 Chevy 3600 Pick-up.
ukwildcat53 Your Engine Cast # will be below and in front of your distributor like here ... The Engine Cast # will tell you when it was used in production... As example mine current engine is 3769716 and it was used from 1958-1962 and is a 235 CI ... Many of these old truck engines were replaced as mine was twice... Yours might be the original engine... Either way the Engine Cast # will be in the same place...
You can also run your Vin # through The VIN Buster ... Your vin plate is located here on the left side of your cab between the door hinges...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
3835913 is the head casting code on a 1954 or 1955 first series 235 engine.
F54M as part of an engine serial number would indicate a 1/2 ton 1954 (3100) truck made in Flint, MI and having a Hydra-Matic (automatic) transmission. Can you post a photo of that plate? It might be an engine code plate that was at one time attached to the Hydra-Matic transmission (the Hydra-Matic's engine and transmission were matched at the factory).
The block casting number for the 1954 and earlier engines is right above the oil pan flange and forward of the fuel pump. [IMG
This area is often covered with road grime.
Hoyt
U
U Offline
I know where the casting number is supposed to be, that is the problem. There is no number below and in front of the distributor or anywhere else that I have been able to find.
U
U Offline
Hoyt
I will have to look at this area. Everything else I have been able to find said the casting number was below and in front of the distributor.
U
U Offline
I will have to take a picture and post it. It is not really a plate. It is stamped on the ledge to the left of where the distributor enters the block.
That stamped number behind distribuitor is engine number, not casting. As Tim said, it is a 54. Casting number will be more accurate than stamped engine number, since they might have stamped it back. Head casting is no warranty either, since some heads fits same block.
ukwildcat53
If you have a Hydra--Matic transmission here is the Plate pic attached to it...
