| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hi all... Grant here. Bad news today... found out the 12 bolt 3:73 posi that I was planning on overhauling for my 59 Apache 1/2 ton is trashed beyond practical use. So now I am considering options. What is available to put into the original 3rd member rear end as far as ratios with a posi unit? I am mostly interested in 3:73 or 3:42. Thanks.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Am I suppose to guess you are talking about a 59 1/2 ton?
If yes, you are limited to 3.90:1, or 3.38:1. As far as I know there is no Posi options available for the HO33 rear.
| | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | I know I have as S104wd rearend,that has 3:73 posi,and some of them have 3:42posi.I would think it is not an original 59rearend?My guess? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Am I suppose to guess you are talking about a 59 1/2 ton?
If yes, you are limited to 3.90:1, or 3.38:1. As far as I know there is no Posi options available for the HO33 rear. The only Posi unit for that rear was the Eaton Positraction, only manufactured from '60-'62/early '63. Nothing in the aftermarket exept for a Miller or Lincoln Locker  .
Bill Burmeister | | |
