0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73840 02/24/2007 10:00 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | ...while I am waiting on the shop for my exhaust manifold...I am looking at the steering.
I have a huge amount of play in the steering wheel, and fight that wander on the road.
So I got the locking nut freed up on the gear box, but the adjusting screw is so close to the wheel well that I cannot get a screw driver in there. And it is kinda rusty to boot.
Can I pull out nut/screw combo? Undo the locking nut until the adjusting screw and locking nut come out? Is there a problem I will create for myself?
I figure once I take it out, I can clean it up a bit and make it adjust easier.
Dave 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#73841 02/24/2007 10:57 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can remove the nut but the screw has a flange on the inside. You would have to remove the pitman arm & pull the sector shaft out . Sometimes you can put a screwdriver in sideways & work the screw in & out with some penetrant on it. If it,s frozen tight you might put some heat to the screw & it might expand the aluminum a little. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73842 07/11/2007 7:05 PM | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | I have what I consider to much slop in my steering as well.... Do you turn the screw in or out to remove the slack ? How much is normal ? | | |
#73843 07/11/2007 7:33 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | There's an adjustment procedure that should be followed. Guesswork can create a binding situation at the center point, or very rapid wear of the worm gear.
1. Disconnect the drag link from the Pitman arm, so nothing but the steering gear moves.
2. Count the turns of the steering wheel lock-to-lock, and position the steering wheel at the approximate dead-center position. Move the wheel approximately 1/2 turn away from center.
3. Put an inch-pound torque wrench on the steering wheel nut, and turn the steering gear through the center point in one smooth, even sweep. A properly-adjusted sector preload should increase the turning torque 10 inch pounds as the center point is passed. The same readings should be obtained when turning across center in either direction. Adjust the bearing preload screw in or out until the reading is correct, then lock the nut and recheck the preload.
For instance- - - - -let's say it takes 5 inch pounds to move the wheel when it's away from the center point. As the center point is passed, the turning torque will rise to 15 in/lb, then drop back to 5 again. If there's a rise, then a slack spot on center, then another rise, the worm gear is worn out and needs to be replaced. Thre torque should increase, peak, and decrease smoothly. The torque values are so low that the steering linkage must be disconnected to get an accurate setting. NO, jacking up the wheels isn't sufficient! Jerry
EDIT: There should be NO slack at the center point, with a little clearance at each side. Jerry
#73844 07/12/2007 2:36 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | this is a monster ...a 1/2 turn too much ..an bad stuff happens ! | | |
#73845 07/12/2007 3:39 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | From what you have described in this and other posts, the parts in your steering gear box are worn out. You can only do so much with the adjustment as others have pointed out. Probably time to get the box rebuilt. Fred
#73846 07/12/2007 5:13 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I agree with rfs56trk. What happens is the worm gear in the box wears more in the general area of the straight ahead position, because that's the direction where the truck is driven the most. As a result, when you get a proper adjustment in the straight ahead position, then it binds in the turning positions (left or right) because those are the areas where the wear is not as much. As a result, you cannot really adjust for a lot of wear. | | |
#73847 07/13/2007 12:04 PM | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | Thanks guys...I will give the torque wrench thing a try. Sounds like I need to be real sure before any actual adjustments happen. | | |
