| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73836 02/24/2007 3:26 AM | Joined: Dec 2006 Posts: 30 New Guy | | New Guy Joined: Dec 2006 Posts: 30 | Have a 65 Chevy C-10, recently replaced steerin' box and would like ta' know what the life expectancy of rag joint is?? Know that bein' a pretty broad question what with the type divin' one does, but just lookin' for a "ball park figure". Pre-thanks are in order. ~Skip
"There's no head like Steelhead" | | |
#73837 02/24/2007 4:51 AM | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I have never replaced a rag joint. I think a close inspection would be the best thing to do, If it looks questionable at all replace it, but I have never seen one fail. Jim | | |
#73838 02/24/2007 5:47 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The newer rag joints have a pin feature that even if the rag tears away, won't leave you without steering.
Normally, a rag joint will begin to take on a frayed appearance before it needs replacing. I've found that a trip to the junkyard can save you a few bucks if you are so inclined. Most bad joints that I've seen have been on 4 WD vehicles with over-sized tires. If your C-10 joint isn't tattered and frayed, I'd say you're good to go.
Personally, would be more concerned with the brake system. Just my $.02. | | |
#73839 02/24/2007 10:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Usually they last 10 years or so but if they get oil on them or are close to the exhaust they can be short lived. Like Fla54 says if they opperate at a heavy angle they will wear out sooner. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
