2 members (ChevyBlue, Otto Skorzeny), 224 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#73836 02/24/2007 3:26 AM
Have a 65 Chevy C-10, recently replaced steerin' box and would like ta' know what the life expectancy of rag joint is?? Know that bein' a pretty broad question what with the type divin' one does, but just lookin' for a "ball park figure". Pre-thanks are in order. ~Skip
"There's no head like Steelhead" wink
#73837 02/24/2007 4:51 AM
J M Offline
I have never replaced a rag joint. I think a close inspection would be the best thing to do, If it looks questionable at all replace it, but I have never seen one fail.
Jim
#73838 02/24/2007 5:47 AM
The newer rag joints have a pin feature that even if the rag tears away, won't leave you without steering.
Normally, a rag joint will begin to take on a frayed appearance before it needs replacing. I've found that a trip to the junkyard can save you a few bucks if you are so inclined. Most bad joints that I've seen have been on 4 WD vehicles with over-sized tires. If your C-10 joint isn't tattered and frayed, I'd say you're good to go.
Personally, would be more concerned with the brake system. Just my $.02.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#73839 02/24/2007 10:01 PM
Riding in the Passing Lane
Usually they last 10 years or so but if they get oil on them or are close to the exhaust they can be short lived. Like Fla54 says if they opperate at a heavy angle they will wear out sooner.
1972 Chevy c10 Cheyenne Super
