Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#73821 02/23/2007 10:34 PM
Hi all! This might be a kinda dump queation!
I haven't changed the fuel filter since I got the 63 burb last August. Napa looked it up and gave me what looks like an insert. I was under the truck trying to see what transfer case I've got ( no luck ) when I noticed the fuel filter. It looks sort of similar to the one in the 78 I used to have. Do I remove the canister from the fuel line and replace the filter inside?
EB.
#73822 02/24/2007 12:46 AM
change it for peace of mind
Jim & Caroline
#73823 02/24/2007 5:14 PM
Hey Eb,
I think your asking if what they gave you at Napa goes in your existing fuel filter housing. Its hard to say without seeing them both. I would say just shut off gas, pull filter and see if it comes apart. If you cant figure it out just take it with you when you go for a replacement. Get something east to replace and readily available. Good luck,
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#73824 02/25/2007 1:05 AM
Thanks guys....I will check out the filter housing Tues but.....another question.....could I hook up a later model filter into the gas line?
EB.
#73825 02/27/2007 2:56 AM
Just read my previous post. That should be "easy" not "east". Darn T and Y are too close together :hammering: I think any modern filter would work fine as long as the lines are the same size. Thats what I meant by east and readily available = later model. smile
1957 GMC 150
#73826 02/27/2007 4:13 PM
Thanks Jeff....makes sense!
EB.
