2 members (fonz8261, RLB),
84
Mod | | | Forums66 Topics128,026 Posts1,055,400 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73821 02/23/2007 10:34 PM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Hi all! This might be a kinda dump queation! I haven't changed the fuel filter since I got the 63 burb last August. Napa looked it up and gave me what looks like an insert. I was under the truck trying to see what transfer case I've got ( no luck ) when I noticed the fuel filter. It looks sort of similar to the one in the 78 I used to have. Do I remove the canister from the fuel line and replace the filter inside?
EB. | | |
#73822 02/24/2007 12:46 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | change it for peace of mind
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#73823 02/24/2007 5:14 PM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Hey Eb, I think your asking if what they gave you at Napa goes in your existing fuel filter housing. Its hard to say without seeing them both. I would say just shut off gas, pull filter and see if it comes apart. If you cant figure it out just take it with you when you go for a replacement. Get something east to replace and readily available. Good luck, Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#73824 02/25/2007 1:05 AM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Thanks guys....I will check out the filter housing Tues but.....another question.....could I hook up a later model filter into the gas line? EB. | | |
#73825 02/27/2007 2:56 AM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Just read my previous post. That should be "easy" not "east". Darn T and Y are too close together :hammering: I think any modern filter would work fine as long as the lines are the same size. Thats what I meant by east and readily available = later model.
1957 GMC 150
#73826 02/27/2007 4:13 PM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Thanks Jeff....makes sense!
EB. | | |
