1 members (WICruiser),
164
0
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | When doing a factory two-tone, my hood will be white on the top side, What color was the underside? White also or or semi-gloss black? The underhood brace bars are semi-gloss I believe also.
Thanks | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The entire engine bay was underhood black or somewhere between matte black & satin black, with the exception of the firewall, which was the main body color. Eastwood has a very nice rattle-can black, called underhood black, that is great for this application. Underhood Matte Black Aerosol Underhood
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Not all firewalls were body color, some were the inside of cab color depending on what plant they came from.
| | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Thank everyone I was about to post the same questions.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Joe. I would like to see one of those. Per the printed literature, the firewall was the main body color, but if you have something that says some were the inside of cab color depending on what plant they came from, I would love to see it. Thanks. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I have seen (mine included) the firewall painted the light fawn. I just sanded mine and the fawn was original to the truck - included truck colored overspray among other evidence. As far as the literature - I searched many sources and could not find any mention of firewall color. My guess is that sometimes/ someplaces painted the firewall with whatever was left. HB | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Pictures would be priceless. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Tony of all the trucks you have bought over the years you have never seen this and you figure the book only states body color then thats all they would have came with was body color on firewall . THE 60 I have was never redone and it had a silver firewall as well as my 62 k-20. My 64 c-60 all original when i bought it had a fawn firewall. This subject was brought up at the 67-72 website. There are several pics of unmolested trucks there with pics of color of firewall both ways. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | It seems like the east coast trucks had the fawn firewalls, IIRC. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | My '65 has original body-color firewall, and was built in Maryland, I believe. PO worked on hood some, can't tell about that.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | One of my 61's had the Silver firewall. 2 other 61's had body color FW's. One of the body colored was from Janesville, WI plant. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | On the non-body color firewalls, where are the paint-breaks, that transition the firewall color from the main body color. From an efficiency standpoint, during assembly, it makes sense, that the interior color stopped at the jambs, windshield lip & back glass lip. Although not impossible, it would be highly unlikely that the interior color wrapped around the "A" pillar and across the firewall, since there would be a great deal of masking required, to transition the interior color at the firewall, to the adjacent surfaces, which then become the main body color.
In my travels, I have never seen an unmolested cab, that has the interior color transitioned across the firewall. Perhaps it was done on the early trucks, say '60-'61...
If I read something from the Trucks Sales Data Book or The Silver Book, I usually take it literally. Especially, since most of the literature is original and published before I was born. Learn something new, every day. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | I guess the book needs to be redone with the things that have been left out. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I figger they painted the whole cab interior & firewall fawn, then added the body color @some plants-if you look at a bare cab it would be easy to drape off the firewall. I also theorize they painted two tone truck cabs white, then added the lower color-I have seen firewall markings indicating "ivory" or "two tone" on many trucks, also found white paint under the body color.
I'm sure things were different from plant to plant-most of mine have been St Louis built trucks, but the burb is from Fremont-I notice a big difference in spot welds, both the number of welds & quality.
over @the 67-72 board there are pics of many fawn firewall 60-66 trucks, i have only seen one IRL though. | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | Find the Truck Painting Regulations. I have never seen the ones for Chevy Trucks, but have for GMC's. They spell out what gets painted what and don't seem to leave any room for artistic license on the part of the the assembly plants. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | All three of my 1966 Lakewood (Atlanta) trucks had fawn firewalls. | | |
