1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 56 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 56 | hello everyone. i have a 52 gmc truck. it had 228 cuin. but its cracked. what motors will fit trans and bell housing.thankyou for your help. its a usa truck bought in las angeles when new, im sec owner and live in west coast canada.thankyou so much for any help. youyrs truly , mike
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A GMC 248, 270 or 302 will replace it. Mid-'50s and newer have side mounts so you'll have to use the front mount plate from your 228. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | What Cletis said!
Don't throw away that 228 without scavanging parts to reuse for the next engine.
Some parts that are always good to keep include the headbolts, flywheel, starter, oilpump pickup and oil pump tubes to block, head, water pump, etc. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | As Cletis says, the 228 will exchange with a 248 270 and the 302. You can bolt up your bell housing and transmission to the later engines too. You will have to change the timing cover back plate in order to have a front motor mount as stock. This will mean that you will have to drop the pan, remove the flywheel and remove the cam in order to replace the timing back plate.
Finding a 228 248 270 or 302 GMC engine is going to be difficult to find in Canada, I think they did not use the GMC engines in the GMC trucks, they used Chevrolet 216 235 and I am not sure about the 261 (Those were also used in the canadian Pontiac's). You will probably have to have an engine shipped from the states.
I am doing the swap also. I have a 1959 302 that I am putting in my 48 GMC Suburban. If you want to keep the six volt, you may have a problem. Finding the correct 6 bolt/6 volt 139 tooth flywheel is pretty difficult to find. The 228 flywheel is four bolts. The newer 248 270 and 302 engines have a 6 bolt flywheel and it has 174 teeth?
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | mikebrou, Call Patrick's in Phoenix. They have complete 2228's, 248's 270's and 302's reasonable. They are Mr GMC inline in my book. Normbc9 | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have a good running complete 228 but your on the wrong side. 168
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know about other years, but in 1954 the Canadian Chevrolet/GMC Trucks Maintenance Manual shows 248 as being standard and 270 GMC engines as being optional on various 1700 series (Chevrolet) & 9700 series (GMC) Canadian trucks. Still, those 248/270 GMC engines were not available on the much more common light/medium duty trucks.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The larger trucks through the AD years came with a 248, in Canada. That includes the Chevs which I believe were called Maple Leafs. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have seen several statements of when the Canadian Chevrolet Trucks with GMC engines last used the name "Maple Leaf". This fellow says that 1951 was the last year for the "Maple Leaf" name (but, then he shows a Maple Leaf 1952 model 1773. He seems to have obtained his information from Canadian GMC/Chevrolet Truck documents. It looks like the GMC-engine-equipped 1952or53-1955 Chevrolet Advance-Design trucks did not use the Maple Leaf name? | | |
