8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian), 149 guests, and 3 robots.
Topics128,042
Posts1,055,522
Members48,424
#738116 04/11/2011 4:43 AM
hello everyone. i have a 52 gmc truck. it had 228 cuin. but its cracked. what motors will fit trans and bell housing.thankyou for your help. its a usa truck bought in las angeles when new, im sec owner and live in west coast canada.thankyou so much for any help. youyrs truly , mike
A GMC 248, 270 or 302 will replace it. Mid-'50s and newer have side mounts so you'll have to use the front mount plate from your 228.
What Cletis said!
Don't throw away that 228 without scavanging parts to reuse for the next engine.
Some parts that are always good to keep include the headbolts, flywheel, starter, oilpump pickup and oil pump tubes to block, head, water pump, etc.
As Cletis says, the 228 will exchange with a 248 270 and the 302. You can bolt up your bell housing and transmission to the later engines too. You will have to change the timing cover back plate in order to have a front motor mount as stock. This will mean that you will have to drop the pan, remove the flywheel and remove the cam in order to replace the timing back plate.
Finding a 228 248 270 or 302 GMC engine is going to be difficult to find in Canada, I think they did not use the GMC engines in the GMC trucks, they used Chevrolet 216 235 and I am not sure about the 261 (Those were also used in the canadian Pontiac's). You will probably have to have an engine shipped from the states.
I am doing the swap also. I have a 1959 302 that I am putting in my 48 GMC Suburban. If you want to keep the six volt, you may have a problem. Finding the correct 6 bolt/6 volt 139 tooth flywheel is pretty difficult to find. The 228 flywheel is four bolts. The newer 248 270 and 302 engines have a 6 bolt flywheel and it has 174 teeth?
1 Offline
mikebrou,
Call Patrick's in Phoenix. They have complete 2228's, 248's 270's and 302's reasonable. They are Mr GMC inline in my book.
Normbc9
i have a good running complete 228 but your on the wrong side. frown
Quote
174 teeth?
168
I do not know about other years, but in 1954 the Canadian Chevrolet/GMC Trucks Maintenance Manual shows 248 as being standard and 270 GMC engines as being optional on various 1700 series (Chevrolet) & 9700 series (GMC) Canadian trucks. Still, those 248/270 GMC engines were not available on the much more common light/medium duty trucks.
The larger trucks through the AD years came with a 248, in Canada. That includes the Chevs which I believe were called Maple Leafs.
1951 1 Ton Completed
I have seen several statements of when the Canadian Chevrolet Trucks with GMC engines last used the name "Maple Leaf". This fellow says that 1951 was the last year for the "Maple Leaf" name (but, then he shows a Maple Leaf 1952 model 1773. He seems to have obtained his information from Canadian GMC/Chevrolet Truck documents.
It looks like the GMC-engine-equipped 1952or53-1955 Chevrolet Advance-Design trucks did not use the Maple Leaf name?
