5 members (Gray_Ghost, Shade Baby, Peggy M, Millenimech, NJC), 90 guests, and 3 robots.
Topics128,120
Posts1,056,321
Members48,439
#737845 04/10/2011 1:48 PM
does the clamshell take the same gasket as the "large" window on the pickups? no one shows the clamshell rubber in their catalogs.
STEELE
Go to the lower portion on the page and find this:
Weatherstrip, upper & lower tailgate. Fits Suburban. Replaces #3766568 & #3766576.
70-1826-72.....$ 145.60/set
I meant for the glass! sorry
it's the same rubber as a pickup glass
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Wasn't your fault, I sent you the wrong code. I think STEELE has what you want.
Vulcanized Back Window Channel
Chevy & GMC Suburbans with lift gate. 60-0702-81
$86.60/ea.
SOOOOOO frustrating, after trying 4 hours to install back glass I now find out that it is NOT the same !@#$%^&* gasket as the pickup back glass! totally different profile! For those of you doing the same project here is the REAL information! The back glass on a suburban is LARGER than the opening! The glass slot is offset from the seam on the door towards the outside of the body so the glass actually sits between the rubber and the seam, NOT inline with the seam.
