2 members (MikeE, carbking),
53
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,129 Posts1,056,360 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | does the clamshell take the same gasket as the "large" window on the pickups? no one shows the clamshell rubber in their catalogs. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | STEELE
Go to the lower portion on the page and find this:
Weatherstrip, upper & lower tailgate. Fits Suburban. Replaces #3766568 & #3766576.
70-1826-72.....$ 145.60/set | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | I meant for the glass! sorry | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | it's the same rubber as a pickup glass | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Wasn't your fault, I sent you the wrong code. I think STEELE has what you want.
Vulcanized Back Window Channel
Chevy & GMC Suburbans with lift gate. 60-0702-81
$86.60/ea. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | SOOOOOO frustrating, after trying 4 hours to install back glass I now find out that it is NOT the same !@#$%^&* gasket as the pickup back glass! totally different profile! For those of you doing the same project here is the REAL information! The back glass on a suburban is LARGER than the opening! The glass slot is offset from the seam on the door towards the outside of the body so the glass actually sits between the rubber and the seam, NOT inline with the seam. | | |
