3 members (baldeagle, Eisenholtz, NJC), 119 guests, and 2 robots.
Topics128,037
Posts1,055,469
Members48,424
#737982 04/10/2011 10:40 PM
Having a problem getting the barke lights to work. I have replaced the switch but was wondering if it could be fuse related? I have the Manual but it does not show which fuses are which. Can anyone post a picture and identify which fuse is which? Also, is there something i am missing on the brake lights? The turn signals work.
Thanks...
Riding in the Passing Lane
You must have a test light for electrical work. You should have current at one term of the stop light switch at all times. When you press on the brake the other term should be hot. If you dont have current to the switch it is probably the fuse. Check both sides of each fuse with the test light. If one side is live & not the other, the fuse is blown. If you have current at both sides of the switch check the wires in the turn switch going to the rear lights. They should be live too. If not the turn switch is bad.
1972 Chevy c10 Cheyenne Super
