7 members (Johnny Rib, dwreills, Gdads51, Rexville48, Wayne67vert, Wickedbass, Peggy M),
147
Mod | | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Having a problem getting the barke lights to work. I have replaced the switch but was wondering if it could be fuse related? I have the Manual but it does not show which fuses are which. Can anyone post a picture and identify which fuse is which? Also, is there something i am missing on the brake lights? The turn signals work.
Thanks...
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You must have a test light for electrical work. You should have current at one term of the stop light switch at all times. When you press on the brake the other term should be hot. If you dont have current to the switch it is probably the fuse. Check both sides of each fuse with the test light. If one side is live & not the other, the fuse is blown. If you have current at both sides of the switch check the wires in the turn switch going to the rear lights. They should be live too. If not the turn switch is bad. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
