6 members (Napco Man, Gray_Ghost, Phak1, Otto Skorzeny, 1955 1 Series, Southerntruck), 114 guests, and 3 robots.
Topics128,110
Posts1,056,242
Members48,437
#737680 04/09/2011 4:42 PM
Hello,
I would like to set up a bench in my shop for testing and repairing radios. So far I have a cheap multi-tester, a tube tester from an old store (don't know if it works), and an old soldering iron. What else do I need?
Chris
Hello again,
The first radio that I would like to test/repair is this 54 car radio that I was not able to get $50 for on Ebay. Item # 200592899471
What should I do first?
Chris
For working on radios, it is good to have a multi-meter. What is really helpful is to have one where the impedance on the voltmeter is high. I have a cheap one that has an input impedance of 10 MegOhms. If you can pick one up, a signal generator is very useful. A unit that allows you to generate all the frequencies in the AM band, and the lower IF frequencies of the radios. They usually have a feature where you can turn an internal tone modulator on and off.
To start with your radio, I would replace all the capacitors and then power it up and check the voltages.
1951 1 Ton Completed
Moderated by  truckernix
