6 members (SmalltownTRKGuy, Gdads51, Lightholder's Dad, GrandpasJimmy, Jon G, Otto Skorzeny), 97 guests, and 2 robots.
Topics128,194
Posts1,057,248
Members48,466
#737591 04/09/2011 9:12 AM
howdy guys
im back to ask more stupid questions grin im sorry if i annoy any one smile
i thought i had finally found a 235 in aus but just checks the engine numbers and it turned out to be a 230.
so my question is would a 230 fit without major modification's in the 38 truck?
i did some searches but turned up blank so hope some one can help me out.
thank you all again and i appreciate all your help.
jeff
all good think i worked it out for myself sorry for dum post grin
230 is longer like a 292
and i can use a gearbox a 3 speed out of a truck as they should also be compatible with my torque tube
I have a 250 in my 37, its a tight fit at the radiator and firewall, but it will fit. If you get the right bellhousing, you should be able to use the stock drivetrain. Make some side mounts to hold the engine in front and you got it made.
Joe
You wont be able to hook up the original rear end easily to a 230 so keep on looking for a 235,I dont think there vere was a bellhousing made that would bolt on a torque tube compatable trans to the later motors.
I was wrong, I was thinking of the early bellhousing with side mounts. Sorry for the miss information. I don't really understand all the manual transmission swapping and parts interchange, I just remember guys looking for the right bellhousing for some reason.
Joe
