1 members (JW51),
96
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I am restoring the bed on the truck now. 63 shortbed stepside. I have replaced the back bed panel and tailgate, have all new strips and bolts, but the angel strips are a problem. Are they welded in? They are most definitely original, but not bolted to the bed side. I have new strips and ordered the ones that are punched, but there are no holes to mount to the sides. Any be great
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory edge angles are welded in place, but the spot-welds can be easily drilled out, in order to remove them. Be careful not to go through both the angle strip and the bed side, since you will be putting new ones in place. When installing the new ones, I drill holes in the new strips and puddle-weld them to the bed sides. After top-dressing the puddle-welds, they look close to factory. They can also be drilled and bolted in place with carriage-head fasteners. | | | | | Joined: May 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 31 | I can tell you that when you remove the strips from the bedsides the bed sides have a tendancie to warp. I like the idea of welding them back in but I used polishes stainless steel. You didn't say what strips you were using. good luck, we like pics too! | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | Jon1963,I noticed in a Jim Carter's Classic Truck magazine,you can order the angle strips,on the bedsides,that will fit over the existing strips,without any welding,or drilling. Check it out might save you time,and frustration,just a thought.Good Luck. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The cover strips have to be attached in some fashion, whether they are drilled & bolted or welded, in order to attach them over the existing edge strips. I don't recommend installing them over rusty ones, since they are rusting from the inside out and the covers will only serve as a band-aid. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I purchased polished stainless steel strips, sorry I didn't pass that on. I don't do welding myself, so I think that I'll just bolt them in w/carriage bolts. The reason I didn't go with the covers is that the angle strips on the truck are in terrible conditiona and I want to replace with new strips and hardware. Thanks for all the help. | | |
