1 members (baldeagle), 54 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#736962 04/07/2011 3:36 AM
I replaced the master brake cylinder, wheel cylinders, lifetime shoes and most of the lines on my 55 Chevy 1/2 ton truck.
I bled the lines and adjusted the brakes per the manual. So the shoes/pads are not touching or rubbing the drums after the adjustment.
But here is the problem. I have taken the truck out for a little spin around the hood and the brake pedal gets gradually stiffer the longer I am driving (no smoke though). The pads are either swelling and/or not backing off of the drum completely. I immediately jack up the truck and spin the wheel and the pads are slightly rubbing. I have tried readjusting them a few times and it keeps happening.
I'm not a pro and it's my 1st project, so I am eager to hear from someone who has been around the block. Am I missing something? Thanks
Robert Greer
55 1st
3B Offline
Hy Chevy3100_55_1st, welcome, please check to make sure that the master cylinder piston is being allowed to return to its completely released position. What I mean is there should be a small clearance between the pedal linkage and the master cylinder piston, and there should be a return spring on the brake pedal, hope that helps.
