0 members (),
108
Mod | | | Forums66 Topics128,105 Posts1,056,539 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | I need to add some fluid to my 1954 3104 Hydra-Matic... Did a search as to what type of modern brand of fluid to use and came up empty... The person at NAPA what worked as a GM mechanic for many years suggested Dextron lll ( 3 ) but said to ask others to be sure...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I ent through the same thing. It seems that type A was made from whales or something like that that caused it to be removed from the parts shelves. I have been using Dextron on the suggestion of Bill Miles. I think the general concensus was that the bads and clutch disc face of H-M trans is very soft and something like a type F would be hard on them. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Thanks Tim & Greg... Will give Gene a call and ask him what they use... Will post back...
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | I talked with Gene at Restoration Hydramatics. Gene said I should use Dextron lll ( 3 ) but that would depend on when my Hydra-Matic was rebuilt... Mine was done sometime I think in the late 70's early 80's... So if your Hydra-Matic has been rebuilt it may require different fluid type depending on when it was rebuilt...
