8 members (Peggy M, Gdads51, GusG, Southerntruck, klhansen, Maybellene, walterhvogel, Hotrod Lincoln),
107
Mod | | | Forums66 Topics128,089 Posts1,056,422 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | I'm pullin the six out to put in a 350 married up to a saginaw 4 speed. what motor mounts do I use? What manufacturer? Anyone have pics? | | | | | Joined: Oct 2010 Posts: 24 New Guy | | New Guy Joined: Oct 2010 Posts: 24 | Sorry I don't have pics tonight. I have a 60 Chev lwb and mine has a 350 and a muncie 4-speed. My front engine mount is actually a horseshoe shape that bolts to the front of the block with 4 bolts and then one bolt at the bottom. On the rear it has mounts on the side of the bellhousing. There is no side motormounts like on a latermodel. | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | if you are pulling out a 230-250 6-cly motor you can use your old frame mounts, and use the rubber mount that are bolted to them, just take the mount apart and bolt the rubber mount to your block, if it is a 292 6-cly you will need the passenger side frame mount. Very easy install. email me if you still need pictures. [email protected] | | | | | Joined: Jan 2010 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 52 | You should also consider the cooling system. If you are replacing a 292 then you can use your old radiator. It is the same size as V8 equipped trucks. You will also need a fan shroud or aftermarket electric fan(s) due to the fact the V8 sits farther back than a 6. The 230-250 equipped trucks used a smaller radiator and may not provide sufficient cooling. | | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | Thanks RJ, mounts are in the mail...that was going to be my next question Miner...I do have the 230..guess I'll have to get a new radiator..aargh!!$$! What would be the best setup?
| | | | | Joined: Jan 2010 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 52 | If you are planning on air conditioning then get a heavy duty 4 core or "Desert Cooler" If not then a standard 292/V8 radiator should work well. Brothers truck parts has a good selection or you could look for a used one. Of course with a new one , you know what you're getting. | | |
