0 members (),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 8 New Guy | | New Guy Joined: Aug 2009 Posts: 8 | Hi everybody, I have 60 C10 with a manufactured in 1964 283 in it,and would like to run a 700r4. People tell me I should just put a TH350 in it because it is less complicated but I need the overdrive. Are there cross member issues?...electronics? Advice on linkages and mounts would be greatly appreciated. Thanks. | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | The only difference between installing the 350 and 700 is the importance of the tv cable and if its electronic you need something to lock the converter up. it will cost an extra couple of hundred bucks. I put a floor shifter in mine from lokar wich comes with all of the linkage you need. I can get under mine and snap a few pics of what I did and send them to you if they will help. just let me know.
you will need the following at least flywheel starter shifter converter lock kit have your drive shaft modified new engine mounts if its horse shoe/trans mounted trans cooler and/or new rad. trans mount tv cable bracket
feel free ask questions. I put mine in last winter so I don't remember everything off of the top of my head but I will help in any way I can. I was a little leary of doing mine at first but I did a lot of research and the trans and the importance of the tv cable and the drive shaft angles. Mine is a 3/4 ton with the x frame so it was a little tight at the rear of the trans but it all worked out well. | | | | | Joined: Aug 2009 Posts: 8 New Guy | | New Guy Joined: Aug 2009 Posts: 8 | Hey Nate! thanks for the info, very helpful. When I have more questions I will let you Know. Thanks, Gary | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I put one in my 64. I now have a 350 with a 77R4. Mine was a 3 speed to start with so I needed a new transmission mount. As well you will need to shorten the drive shaft. Add a new brake switch. One that will work the brake lights on when you push the peddle and also remove the power (much like cruise control) to the transmission. And as stated you must make sure the TV cable is rigged correctly. | | |
