5 members (Tronman, Phak1, 32Fordpuchoptop, Ponchogl, k2handyman), 88 guests, and 2 robots.
Topics128,042
Posts1,055,520
Members48,424
#7357 05/19/2003 6:09 AM
The oiling tube that comes off of the head and runs up to and around the center of the rocker arm rack is broken off. How important is this tube? Do I need to replace it? The engine is a 54 235.
46 GMC
#7358 05/19/2003 6:16 AM
It may look broken off but isn't. It kind of ends and I believe is crimped at the end on the 54. You mean underneath the valve cover right?
54 3100 with 235
62 flatbed dump C60 with 261
#7359 05/19/2003 6:21 AM
You're right... it is crimped off. I used to have a 216 and that tube ran right around, with-out a crimp. Is the tube even needed?
46 GMC
#7360 05/19/2003 6:59 AM
The earlier type of tube just went up from the head to the ring between the rocker shafts and wrapped around. Then it just pointed down toward the head. The one you have will be fine as being pinched off, it allows a little more oil into the rocker-shaft.
